I?ve got a 31? deep-vee mono hull, that originally came with a cheaply made stinger were the bearings let go after 2 runs.
I rebuilt it, filling the whole stinger strut with (6) 4x7x2.5mm bearings, & using a flange bearing next to the drive dog as a thrust bearing. It lasted all summer, then the back of the stinger strut blew out.
I only use the boat for enjoyment, haven?t done any club races since the late ?80?s, & that was all nitro models, mono, & O/B tunnel hulls.
So I decided to at least upgrade to a 3/16? prop shaft, (original is 4mm on .150? flex shaft).
But I can?t decide if I want to go with another stinger setup or a standard strut.
Are there any pros/cons between the two?
Thanks,
Shadow
