Results 1 to 5 of 5
Thread: stock motor wire upgrade
    Sep 2008
    CA
    83
    Default stock motor wire upgrade
    I have upgraded the ESC in my Blackjack and I am not liking the 10 gauge wire 6mm connectors going down to 14 gauge wire (or whatever it is) on the motor.
    Is it possible to take apart the can and upgrade the wires?
    Boats:
    Proboat Apache 24
    Proboat Blackjack 26 Brushless
    Aug 2007
    CA
    3,031
    not really...
    the outbound cables you see are part of the winding of the motor. Aside of that, the wires are insulated and one could not solder the ends to a bigger gauge wire.
    Sep 2008
    CA
    83
    Then what is the best way solder the smaller wires into the larger bullet connectors?
    Boats:
    Proboat Apache 24
    Aug 2007
    CA
    3,031
    what size are the connectors?
    if they are 5.5mm then just flood the inside of the connector w/ solder,
    put a little solder on the exposed wire then melt the solder in the connector
    and shove the wire in it. That's what I had to do with my SV setup.
    Sep 2008
    CA
    83
    Thats what I figured but had to ask. I am going to get some quality solder and go to town...
    Boats:
    Proboat Apache 24
