Results 1 to 7 of 7
Thread: Twin mono ruder set back
    Aug 2008
    7,080
    Default Twin mono ruder set back
    Anybody have experience with rudder setback?
    I assume that screw separation should be minimal, and rudder should bare some perfect distance back.
    Boat is baby sv43, I?m thinking of having 48-52mm props 1/2? separation, set back from transom 3.5? or so and debating on how much distance between props and center mounted rudder... 2in? 3in? More, less?
    Please, respond if you have experience and/or data to support recommendation.
    Jesse
    "Look good doin' it"
    See the fleet
    Aug 2008
    7,080
    Nobody?
    See the fleet
    Nov 2008
    Ql
    3,169
    Hi Jesse.
    I have only built one twin mono. A 44" Wasabi.
    I don't know if the setup is optimum, so I was a bit reticent to make any suggestion as I thought others with more experience would have by now.
    The struts I used placed the leading edge of the props at 2-1/4" from the transom.
    The rudder leading edge is 4" from the transom. The longest standoff bracket that I had at the time. Not much of a gap between the trailing edge of the props & the rudder. Should possibly be more.
    Here's the thread if it is any help.
    https://forums.offshoreelectrics.com...ghlight=wasabi
    Cheers.
    Aug 2008
    7,080
    Hey Paul, thanks for chiming in!
    Man, what a beast! How did she feel while driving? Turns, straights, in the air?
    See the fleet
    Nov 2008
    Ql
    3,169
    It actually feelt pretty good in both the turns & the straights. Although I didn't turn too tightly around the bends.
    The driving in the air was a bit anxious. but she kept running.
    Unfortunately I haven't run it much since then. The offshore class that it was built for, never really got off the ground at our club.
    Motors & ESC's were robbed for other projects.
    Aug 2008
    7,080
    What was actual distance between prop shafts?
    and it looks like the rudder was about an inch behind the back of the props?
    See the fleet
    Nov 2008
    Ql
    3,169
    The shafts are 2.5" apart.
    The leading edge of the rudder is almost level with the trailing edge of the props.
    As I said, it should probably be a bit further back, but I have no idea what the optimum distance would be.
    Cheers.
