I am having problems getting controllable throttle response with this setup. The Transmitter and Receiver seem to bind Ok, I have rudder control and I get the power/motor connection verification signals from the esc but, I have No throttle response. No matter how many times I try restarting I get the same result. I have tried reversing the throttle signal also.
I have attempted to reprogram the battery type and cell count (Section 1) to 6S, and I believe I was successful. I also attempted to set the Throttle Options to ?auto throttle calibration?. I also believe that I should set the starting power to ?Low?, but am not certain that this is set correctly.
The weird thing is that occasionally after exiting the programming mode the Motor spins up at high speed for a second or two then if I go to brake position stops and will not spin up again!
My first thought was that this esc could not run the NEU 1527? Anyone know?
Anyone have any ideas how to get this thing working?
