Results 1 to 14 of 14
Thread: H&M mono torque roll
    May 2009
    UK
    601
    Default H&M mono torque roll
    Just wondering if anyone could advise, I have a fairly well dialled in no step 4,
    setup is 3060, 10s, 40.160, S235 prop and speeds are 80-85mph (gps'd at 79.5 on a small lake) the boat has a tendency to roll a lot under full beans, is it just a limitation of the hull or should I be able to trim it out?
    here is a few pics for people to sink there teeth into
    It's a fairly heavy boat, well reinforced I checked the obvious like the rudder linkages etc. I've never ran a fast mono so could do with some pointers.
    2x Graupner Azimut atlantic challanger, HPR 115, H&M NoStep4, Etti mono 1.
    AZ
    7,790
    How sharp is the prop? Detonguing the blades might help a bit.
    You can bias the weight (packs) to the left so it sits slightly deeper on that side.
    Lower the inner right trim tab slightly (or more), the outer tab is missing its adjustment screw, a bad thing on a fast boat.
    Raising the whole stinger can help especially if there is much chine walk.
    Which 3060 motor?
    What cells? 10S2P?
    May 2009
    UK
    601
    Prop is pretty sharp, I have a 457 cut to 52mm I can try which is fresh from andy b,
    I don?t actually use it for oval, just playing around, will run it for saw if the uk ever has a event with a big lake..
    3060/7, 1000kv
    The boat is only 1 meter long so really not much space for moving the packs around 10s1p sls quantum 65c
    The screw is actually still there, it?s just snapped, it keeps the trim tab in place but can?t be adjusted seized in place..
    I will try what you?ve suggested with the stinger
    May 2009
    UK
    601
    Have a few props to try now, all fair bit bigger just with this lockdown we are having its not the easiest for testing.
    Have x457 cut to 52mm, X457, 460, 460/3 S255 all to try...
    Mar 2011
    BC
    7,376
    Quote Originally Posted by vvviivvv View Post
    My pal Andy always said the torque roll is ok if the hull settles back out in 3seconds from take off. How does yours fair on that advice?
    May 2009
    UK
    601
    I'm a complete novice at mono hulls in this speed range - so without trying to sound too stupid,
    It's fine in flat calm water but even a slight ripple could be passing over it's own wake will unsettle it and set the torque rolling, normally because of the lake size and the speed of the thing 75mph+ I don't have another 3 seconds to keep it planted...
    maybe it's not torque rolling im experiencing? I do know the fast mono's over in Germany 90+ don't have a ride pad at all...
    Jun 2015
    Mt
    104
    Maybe the OP is talking about chine walking.
    Mar 2011
    BC
    7,376
    Quote Originally Posted by bhorowitz View Post
    Sure sounds like it. I have a DF 35” that used to be like that till I raised the prop/strut and put the tabs to work. It was fast as heck but uncontrollable all the way to point of submarine dives, lol.
    May 2009
    UK
    601
    Indeed, Chine walking sounds more likely, the boat is absolutely fine at full pelt in a flat calm, just gets unsettled (knocked off its ride pad) and it's all over,
    Best thing to start is raising the strut then? I'm going to try and run tomorrow, X457 prop instead of S235 and will move up from that depending on how it behaves.
    Mar 2011
    BC
    7,376
    Well, how did the props do? And yes if you raise the strut then you effectively get a little more Hull in the water and it will get more stable. So bigger prop=less hull in water
    May 2009
    UK
    601
    Unfortunately with UK being back in lockdown I haven't had a chance to give it a run, my big lake i normally run is close to my holiday home and until dec 2 we aren't allowed to visit holiday homes.. weather has been typically British also.
    Dec 2011
    On
    432
    While your waiting for covid and weather check out ABC props. I run 2515-17-45 for a T mono. 10s2p. The octura x450 is a lifting prop. ABC are not, Should allow your boat to settle in the water.
    Aug 2018
    Ky
    112
    Quote Originally Posted by jaike5 View Post
    What is the KV on the motor when you run the ABC prop?
    Dec 2011
    On
    432
    Its LMT 3080/7T 750kv, 44" DF snipper.
