Page 1 of 10 123 ... LastLast
Results 1 to 30 of 279
Thread: Zippkits jae 21fe v2 outrigger_wood kit build
    Jul 2018
    WI
    1,013
    Default ZippKits JAE 21FE V2 Outrigger_Wood Kit Build
    I think I've always wanted to build this kit. It seems like everybody's ZippKits outriggers run really good.
    This is the JAE 21FE V2 kit. They call it a 33FE in the manual. Version Two of their popular 21FE outrigger. I'm not sure why they don't just rename it the JAE 33FE?
    Either way, it's a longer tub and can easily handle a 6s setup, which is why I chose it for my next build. I know it's a bit in between classes, but that's ok, I don't race. Maybe I should make it a 4s build. Maybe that's the sweet spot for this design. But I want a 6s ZippKits rigger.
    So, I'll try to apply what I've learned so far after building a few boats. I'm thinking, build it fast and light. And that's the priority, not looks. And take it to my lake and ring it out.
    I'll still fuss over my build quality. I can't help that, that's who I am. But I really want to go fast with this boat.
    Here's a few pictures to start with...
    Jun 2015
    Mt
    109
    Will be watching, love your builds.
    Jul 2018
    WI
    1,013
    Aw man, thanks
    Jul 2018
    WI
    1,013
    Here's a link to my YouTube channel. Started a video build series there...
    https://youtu.be/yD_dBMvv800
    Jun 2015
    Mt
    109
    cool
    Jul 2018
    WI
    1,013
    I'm not sure how much info is out there on this JAE33 rigger. I've seen quite a bit on the JAE21, the original version. The JAE21 is a true 4s rigger and even runs well on 3s.
    But on the ZippKits website they say the JAE33 can be setup for 4s or 6s. I'm going with 6s, and the TP Power 4070 is a long can. It's 40mm diameter x 100mm long.
    So I did a mockup on the tub to check the fit of my electronics...
    Jul 2018
    WI
    1,013
    I had to know if the motor would fit under the cowl. If not, I was going to use an OSE mount so I could lower the angle.
    It easily fits. This is a true 6s size tub...
    Jul 2018
    WI
    1,013
    This is good to know now, since the stock mount gets epoxied into the tub. Otherwise I would switch out the stock mount and replace it with a wood former to save weight.
    Also, the stock mount weighs less than half of the OSE mount.
    One ounce versus 2.3 ounces...
    Jul 2018
    WI
    1,013
    Here's a look at the JAE33 tub mocked up with 6s electronics in it. That's a ZTW 200 amp ESC in there with a pair of 3s Revolectrix 5000mah lipos!
    Jul 2018
    WI
    1,013
    Link to Part 2 of my YouTube build series...
    https://youtu.be/FFPSAIkQY-s
    Jul 2018
    WI
    1,013
    Here's the specs from ZippKits website...
    Jul 2018
    WI
    1,013
    I'm pretty sure ZippKits is saying a 82mm long motor fits. Whereas the TP Power motor designation for a 4050 is 82mm long.
    Why does this have to be so confusing?
    Jul 2018
    WI
    1,013
    Now I know a 100mm long motor fits...
    Sep 2012
    Tg
    1,441
    How's the CG?
    Jul 2018
    WI
    1,013
    Quote Originally Posted by Peter A View Post
    How's the CG?
    No idea yet. I've simply placed the electronics where the instructions show them to see if they fit.
    The JAE 21 runs a very rear biased CG at a 60/40 weight ratio, with 60% of the weight on the front sponsons.
    Does anyone know where the CG should be on this rigger?
    May 2014
    636
    How's the CG?
    I think he will have to move the ESC forward of the motor.
    Ron - The Villages, FL
    Jul 2018
    WI
    1,013
    Quote Originally Posted by zooma View Post
    I think you're right. I've been reading the 6s jae thread, looks like everyone has the esc in front of the motor.
    Also sounds like the CG two inches behind rear of turn fin is good. That's the 60/40 ratio the JAE21 likes...
    Jun 2011
    789
    Actually TP motors numbering makes the most sense. 40XX = the length of the rotor. 4050 is a 50mm rotor.
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    Jun 2010
    Mi
    738
    Going with the stock motor mount means that there is space under the motor that you can put a relatively flat ESC, like Etti or Swordfish.
    Jun 2011
    789
    Or you can move the motor to the rear with a shorten driveline (less friction) and put battery up front with ESC in between (shorter wires). I used the JAE tub made my own motor mount out of plate in kit and built sponsons similar to KEPs
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    Jul 2018
    WI
    1,013
    Quote Originally Posted by HTVboats View Post
    Interesting layout, and similar to a layout I thought of doing...
    Jul 2018
    WI
    1,013
    Well, I've made my decision on the motor mount. I'm going with the OSE mount with rear support. I'm setting it at the same angle as the stock mount and locating the motor in the stock position in the tub. The ESC will fit in front of the motor.
    This also means I can use the pre-bent stuffing tube I bought with no mods to the former it goes thru or to the laser cut hole in the floor.
    Jul 2018
    WI
    1,013
    I'll also have full range to move the batteries for CG adjustments.
    Jul 2018
    WI
    1,013
    Here's a modification I did to lower the battery tray. I'll roll some pictures, let them tell the story. Those are 5,000mah 3 cell lipos btw...
    Jul 2018
    WI
    1,013
    A pair of 5000mah, 4s Revolectrix...
    Aug 2009
    422
    I built the fe 33 as per the instructions except I?m running a tp4060 1650kv with a single 6s 4400mah. I just made the battery hatch with a hump.
    :canada
    Jul 2018
    WI
    1,013
    [QUOTE=ezhitz;750342]I built the fe 33 as per the instructions except I?m running a tp4060 1650kv with a single 6s 4400mah. I just made the battery hatch with a hump.
    I guess that works.
    No offense meant, but it would be painful for me to do that...
    Your rigger runs nice. Did you hit something in that video?
    Jul 2018
    WI
    1,013
    I'm sticking some wood together with epoxy. The build begins...
    Jul 2018
    WI
    1,013
    Here's the tub built and weighted while the epoxy cures.
    Second one is a picture of a nice straight and square tub...
    Jul 2018
    WI
    1,013
    Here's how I filled the slots for the stock motor mount(that I'm not using).
    I cut pieces from a parts sheet that had the laser burns on it. This gives me the option to leave the tub natural and just clear coat it.
    Instead of seeing epoxy, or wood filler, it looks like the end of a former...
