It isn?t possible to answer your question. It all depends on the WOT amp draw of the system, a low draw RTR can handle a lot of part throttle while a full race setup can?t. This is because the ESC switches on and off to control speed and whenever it switches on it sees full amp draw - which means heat. So part throttle at near top speed is easer on the ESC than part throttle idling along.
IME the Raider is a good ESC, but saying ?6S? really tells us nothing. What motor and prop? What hull? Sport running, SAW or oval racing? It all matters. If you absolutely need a number, 20 seconds total would probably be okay with most moderate setups....but at what speed? It all depends and experience is the best guide.
