Page 1 of 2 12 LastLast
Results 1 to 30 of 47
Thread: Baby sv43 twin build
    Aug 2008
    7,080
    Default Baby sv43 twin build
    Started with paint this time.. then have an idea to go one motor and twin screw, via gear box. Should have 3/16? collets back soon and can start working the 5* slant transom. Made most graphics m?seff.
    Now working on motor/gear box rails .. here is mock up.
    "Look good doin' it"
    See the fleet
    Aug 2008
    7,080
    Default Motor mount v2.3
    Here is my home design of a motor, esc and gear box mount.
    When I?m totally happy with functionality, I?ll have it cut out of cf.
    See the fleet
    Aug 2008
    7,080
    Default Mount and hardware mock up
    Here it is inside and ready for stuffing tubes.
    Mounted rudder and mocking up the drives. Still have trim tabs to mock up, but this is where she sits now.
    See the fleet
    Feb 2019
    385
    Learning time for me. Why wouldn't you move the motor back and the gearbox forward and attach the motor directly to to the gearbox? That 2 inches of flex shaft looks really sketchy to me. Are the couplers square drives so that the flex shaft floats between the motor and gearbox? Also I would worry about the flex shaft coming undone or trying to knot it's self up because there's no support tube around it.
    Like I said just trying to learn. Looks cool.
    Aug 2008
    7,080
    Good points Paul; I’m totally open to this kind of input!
    So, my thinking is this: goal #1 is to keep cog as low as possible. Funny you say connect the motor directly to the gear box..I asked myself the same question 1 hour ago!
    The gearbox needing 8* of down to the back would put the motor a couple inches higher.. making this a self flipping hull?
    You are the second of two people to have worried about that 1.75” of open cable... maybe I should be concerned too.
    Thanks for your comments!
    See the fleet
    Feb 2019
    385
    I don't think you would need the 8* down angle with the gear box. Level the gear box out and you can do that with the 2 stuffing tubes connecting to the gear box by putting gentle s bends in the stuffing tubes plus if you move the gear box back it wouldn't be as drastic. The one thing to consider is the CG.
    Aug 2008
    7,080
    Thanks for the idea Coop; now’s the time to change.. I’ll mock that up and see how it looks.
    I’m not a fan of S bends.. but I’ll see how severe they need to be. I would need to do some amount of S to get the props closer together than the 3in width of the gear box out put shafts.
    See the fleet
    4,119
    I have no actual data to back it up, but I would not trust that open section of flex cable between the motor and gearbox and would not settle on that design during my own mock-up. I agree, lower is better on CoG, but reliability is pretty high on the list too.
    Aug 2008
    7,080
    Default Power module V3.0
    Howdy,
    So upon stern recommendations.. I revamped the design and now have a straight shaft and a servo mount!
    A few minor tweaks and then carbon fiber final!
    See the fleet
    Feb 2019
    385
    Howdy,
    Stern... ROFL. Nice work . I'm going to assume you want to use the drive shaft between the gear drive collet and the motor collet is because either the collet on the gear drive is to big to clamp onto the motor drive shaft or because you you want the motor where it is for CG? Looks great though. Can't wait to see it out of Carbon fiber.
    Aug 2008
    7,080
    Yes, motor shaft size 8mm, gear box collet 0.25”.. thanks coop for the “nudge”!
    See the fleet
    7,630
    Nice rails made there Jesse, these are such nice hulls . Keep up the great work.
    PS: have you spun the setup up yet? Very loud?
    Aug 2008
    7,080
    Hi Shawn,
    Yes the rails have been a lot of trial, modification recut and repeat. But I think with a few final minor tweaks, they are ready for carbon!
    Funny you ask, it did cross my mind to text the system.. I may try it on low power on the bench; I’m curious to hear it as well!
    See the fleet
    7,630
    Yes b I am just curious as this setup is what I’m leaning toward on my BBY drag hydro
    Aug 2008
    7,080
    Supposedly there is about a 10% loss in efficiency.. but I don’t have any data.
    I’ll fire it up and post video. Beauty of this power train setup is that once the rails are cut from cf, the build will be nearly complete.
    If you need a copy of these rails, I know a guy..
    See the fleet
    Aug 2008
    7,080
    So I tested it and was pleasantly surprised. The mount rattled a little, but other than that about as noisy as the motor itself.
    I’m pretty excited to hear it in action on the water!
    If I can figure a way to upload a vid without having to make a YouTube I’ll post here.
    See the fleet
    May 2009
    UK
    1,018
    im getting away with exposed Flexi
    I preferred it than having Flexi to just take any misalignment out and help with vibrations.
    albeit lot less strain in my setup.
    motors are NEU 1521
    Uk SAW record holder
    Aug 2008
    7,080
    That’s what I’m talking about! Cheers, Liam, great addition to the thread!
    How many runs has this set up had?
    See the fleet
    May 2009
    UK
    1,018
    it's been through about 4 runs so far and no issues - I know you are spinning a gearbox and 2 props but I think it'd survive. if it doesn't you could always move to bigger Flexi with different collets...
    Or one of them little MHZ stuffing tube supports with some stuffing tube... have them in my HPR but it's in the paint shop.
    May 2009
    UK
    1,018
    Quick question for you Jesse,
    This is the 980mm hull?
    I'm considering one, I could even use the power train above on 6s, I know twin 1521 Neu are a little overkill but I'd like to get it well into the 70 mph+ zone
    Would probably get another MGM 28026 just for a little bit more ESC power, I have a new one on the shelf ready for a project...
    Aug 2008
    7,080
    Liam, I think you are thinking of the baby raptor, or the baby baby sv43... the baby sv43 in this thread is 48” so I wouldn’t attempt even twin 6s.
    The baby raptor works great on 6s. I have a TP 4070 1700kv, 48mm prop in this video.
    See the fleet
    May 2009
    UK
    1,018
    Yeah, I think "brusher Andy" sold the baby mould to a gentleman by the name of Denis Olivier Mainh?lt
    I'm trying to get the smaller one, I think pushing the 48" hull would be close on the NEU's but maybe possible...
    I think the hull I actually want is your baby raptor from that video, can you share some pictures of it? does it have a thread? what speed on 6s are you seeing?
    think I can squeeze 2 Neu 1521's in? having a slight bend away from the centre line with some custom motor mounts?
    4,119
    The smallest Outerlimits SV43 is the Baby SV43. It's 48" in total length with a 4" overhang. It's a V-bottom, stepped hull and made by Brusher Andy in Germany, who also builds a 65"(66"?) full sized version.
    The RSV Raptor is a non-stepped, v-bottom hull with a total length of 38". The overhang is 2-3" long, I don't have it written down. It was designed by Brusher Andy and the mold was sold to Denis Olivier Mainholt who makes and sells the bare hulls.
    Jesse, has this boat hit the water yet?
    Aug 2008
    7,080
    Jay, it has, but the water was confused and it bounced off...
    No. We are waiting for global warming to kick in!
    Motor mount is completed and I owe you all pics.
    It is close; when the thaw happens AND I get her assembled.. watch out!!
    See the fleet
    Aug 2008
    7,080
    Default Cf power module
    So after at least five cuts of practice ply, one cut of cf/Kevlar (too fuzzy), one cut of cf glossy on only one side (again fuzzy), and then the final cut cf glossy on both sides....
    Power module is Ready for glue!!
    See the fleet
    4,119
    nicely done sir
    Feb 2019
    385
    Jesse that's sweet .
    Aug 2008
    7,080
    Thanks guys, it’s been a long road!
    I’m really looking forward to maiden run!
    See the fleet
    FR
    2,096
    What is the max RPM with this gearbox?
