Results 1 to 5 of 5
Thread: Aluminum stuffing tube?
    Mar 2009
    AZ
    992
    Default Aluminum stuffing tube?
    Is aluminum tubing suitable for stuffing tubes?
    Feb 2019
    NY
    385
    Aluminum gets work hardened as you bend it . If you don't get it right the first time it may crack if you try to bend it back . Also I'm not sure how long it would last against a steel flex shaft unless you're using a teflon tube inside it . Others may have more info.
    ON
    9,402
    If you don't use a teflon liner it won't last long against hardened steel flex shafts. Do you really think you need to save weight or is it just what you have handy?
    Brass is pretty much a standard. A decade ago we used to b worried about weight but not so much now.
    Mar 2009
    AZ
    992
    I picked up a couple brass tubes at ACE and saw that they offered 5/16? in aluminum. It was just a curiosity.
    Feb 2008
    GB
    2,731
    As well as being weak, it is really sticky compared to brass or stainless so you need a liner for sure. I have used it in the brushed NiCad days when weight was more important (and I didn't know about wires), so I can say that with a liner it does work to some extent.
