Results 1 to 27 of 27
Thread: H&M Freya hull finishing
    Oct 2020
    ZH
    50
    Default H&M Freya hull finishing
    Will start finishing this hull over the next weeks. Looking for tips to find the best quality decals. From H&M or from MHZ? Or alternatives? If MHZ, probably 84cm version?
    Verzonden vanaf mijn iPhone met Tapatalk
    Oct 2020
    ZH
    50
    Start is there
    Oct 2020
    ZH
    50
    Paintwork done
    Oct 2020
    ZH
    50
    Update: steering and electronics
    Aug 2008
    7,080
    What decals are you looking for?
    "Look good doin' it"
    See the fleet
    Sep 2020
    MA
    118
    Related to the decals - if one wants to place them on the painted hull, before applying the final clear coat, will they stick well? Or should decals be applied on a really smooth surface for maximum adhesion? For example, does it make sense to spray 1-2 coats of final clear (no sanding) then decals, then a few more coats of clear?
    Oct 2020
    ZH
    50
    Strut level a good starting point for this hull? What do you think?
    Aug 2008
    7,080
    Looks good to me, I suspect it will only go up from here, but only one way to find out!
    What motor, voltage and prop are you starting with?
    See the fleet
    Oct 2020
    ZH
    50
    6s, sss 4092 1650kv, x443 to start/ x445 prop later.
    Mar 2020
    NH
    326
    If you can set the prop 5mm higher less load to start with, i have a mistic 114 single motor (4092 1400kv on 6s)and run so good
    I have excellent results with Prather props
    Oct 2020
    ZH
    50
    Quote Originally Posted by koen View Post
    Ok, great. Will start with the strut a bit higher. Thanks guys
    Technically ready to test somewhere next days.
    Aug 2015
    199
    Need to rotate that water jacket to get the exit line on top. Looks like the exit line is near the bottom, the jacket wouldn't fill but a quarter of the way.
    Oct 2020
    ZH
    50
    Thanks John, maybe my aquatic skills are bad. Why is that? You suggest to push the water flow upward in the jacket? In the direction below? Or do you mean to rotate the nippels facing upward?
    Aug 2015
    199
    Fittings on top, exit nipple should be the highest one, that way cooling can is full of water before exiting to get maximum use of the can.
    Oct 2020
    ZH
    50
    Oct 2020
    ZH
    50
    Bit of detailing during Christmas
    Apr 2020
    702
    Quote Originally Posted by ArnoudRC View Post
    I like...simplistically bold.
    Feb 2019
    385
    Looks great. Is it an optical illusion? It looks like your rudder isn't straight up and down. Looks like the front bottim tip is kicked back a little. If it is it may cause some issues .
    Oct 2020
    ZH
    50
    Hi, no. The position is ok.
    FR
    2,096
    You can make your own PDF files with wanted logos and a pro will print your file on clear or white adhesive vinyl, You choose logos and their size.
    Aug 2018
    12
    Think there decals are from the same supplier.
    Mar 2020
    NH
    326
    H&M and MHZ they have excellent decals
    Aug 2018
    12
    Skickat fr?n min XQ-AS52 via Tapatalk
    Oct 2020
    ZH
    50
    I know. Had some high quality vinyl sponsor decals laying around. Personal touch and saved quite some money
    Dec 2011
    561
    Lose the Y fitting. Water follows the path of least resistance. I use a manifold to get full pressure to both the motor and esc. You can also restrict the esc line out with a zip ty to equalize the pressure in both lines if you choose to leave the Y in. Not a fan of restriction!
    Happy New Year!!
    cheers, Jay.
    Oct 2020
    ZH
    50
    Thank you! Wish you also all the best. On the y connector. You are right. I?m working on a water pump to get enough pressure through a single line (>esc> motor) Will test that setup.
    Feb 2019
    385
    Why not use a duel pick up rudder or a inhull pickup through the bottom of the boat in one of the ride pads. A lot less weight than adding a water pump. Plus you wouldn't be eating up run time powering a water pump.
