Hi all I could use some help on my new TFL Zonda. It has SC: Seaking 120A ESC's and Motor: SSS 3674 2075KV brushless motors. I Set the throttle range with my transmitter Skyfly Noble.
The ESC's didn't come with on/off switches so it makes it a pain in the butt to do the throttle range setup.
Where I'm having trouble is the Starboard ECS, the led is flashing really fast and beeping when the batteries are plugged in and does not stop . The Port side does the cell count and it's fine. I squeeze the throttle and the port side motor spins up like it should. The Steering servos working fine also.
I tried swapping the wires around on the starboard ESC to the motor but that didn't make any difference. Ideas???
Edit: I also went through the Trouble shoot guide that came with the ESC's . It mentioned that one of the batteries could be low so I also tried swapping batteries from side to side it made no difference.
