Results 1 to 2 of 2
Thread: Glue to use on motor mounts
    May 2016
    Mi
    82
    Default Glue to use on motor mounts
    Hi guys
    Wondering what glue u use t9 glue in the motor mounts to the hull? I assume it kinda thick to stay in the little holes in bottom of mount. Let me know what yoU use? Thx
    2,731
    Epoxy laminating resin or glue depending on how far into the build I am If I have a few things still to glue I use laminating resin which is lighter and stronger but needs to be weighed out, or if I just have a mount to put in i find it much easier to use Epoxy glue with its 50:50 mix ratio by volume.
    for race and sports boat with either matrix I mix it with glass microballoons to thicken it up, for SAWs boats I thicken it with carbon powder.
