Results 1 to 12 of 12
Thread: 3 blade 1.4 pitch prop
    Jun 2012
    ny
    1,135
    Default 3 blade 1.4 pitch prop
    looking for a prop a little bigger than an octra 440/3 I see the next size up in the octra line is 447/3 and I'm sure is to big for my p hydro whiplash. I use the 447/3 on my 1/8 scale with great results. Any and all help would be appreciated thanks
    4,100
    ABC makes a 1616, which is essentially a 40.6mm diameter, 1.6 pitch ratio. Nothing from Octura in that size, unless you had a 447/3 cut way down, but those are hard to come by to begin with.
    Mar 2020
    NH
    319
    Look at Modelbaucentre lorenz they have a ABC 1715 3blade and a lot of ABC props
    Dec 2010
    3,116
    I have 1614/15/60/3 a bit bigger Jeano
    Dec 2010
    3,116
    Quote Originally Posted by koen View Post
    you better double check that ?
    Jun 2012
    ny
    1,135
    Chris, whats the diameter of that prop? Is it a 1.4 or 1.6 pitch? How much, $ thanks
    Dec 2010
    3,116
    1.6 diameter 1.4 pitch ratio $70 plus the shipping
    Jun 2012
    ny
    1,135
    My calculations is only .03" bigger than what I have the octra x440/3 don't think that would make a very big difference. What you think?
    Mar 2020
    NH
    319
    modelbaucenterlorenz.de in Berlin
    4,100
    the 40.6mm diameter and same pitch ratio are not the numbers that matter here. The ABC props have more rake on the blades than the Octura props, which equates to more thrust. It also changes other characteristics like the amount of lift they produce at the transom of the hull.
    Jun 2012
    ny
    1,135
    Thanks for the information I'm not that familiar with ABC props and props in general
    Jun 2012
    ny
    1,135
    Chris, I pm'ed you on prop payment
