Results 1 to 15 of 15
Thread: Where to buy 1/8" carbon fiber plate?
    2,913
    Default Where to buy 1/8" carbon fiber plate?
    Where can I buy 1/8" carbon fiber plate?
    9,402
    Why 1/8" ? Most come in Metric and they aren't perfect.
    Apr 2020
    702
    I've never seen CF sheets (technically, "planks") in imperial measurements...only metric. That being said, you can find them on a few websites, c including OSE, Avid (also great for bearings), Amain, and others.
    2,913
    I know that OSE has 2mm, I would like something thicker for a motor mount in a twin (56mm motors) 8S cat.
    I could get the the 2mm from OSE and sandwich them together to make 4mm.
    4,119
    I used to buy most of my CF plate on eBay but post COVID prices from China are pretty ridiculous.
    Apr 2020
    702
    Avid RC (which I previously mentioned) carries 95mm x 295mm sheets, in thicknesses from 1.5mm, up to 5mm. Super-high quality products, and racers have been using (and winning with) their bearings for years.
    Mar 2018
    95
    Try this site. All kinds of useful stuff.
    https://www.mcmaster.com
    Jun 2015
    Mt
    109
    I get all my carbon fiber stuff from ACP Composites. They have CF plate that measures .127"
    Dec 2014
    Ga
    544
    Larry,
    Why carbon fiber for motor mount rails? For the "LOOK" of carbon I suspect. It would have no real world advantage over fiberglass in this application.
    I use this 1/16" G10 FRP for all my rails, up to 56mm motors, then I switch to 1/8", although I truly believe that the thinner plate would really be strong enough to handle the big motors. G10 is a LOT cheaper than carbon too.
    https://www.mcmaster.com/catalog/126/3873/
    Dec 2014
    Ga
    544
    2,913
    This is the type of mount I want to use, it will be for a 56mm motor, No tail ring, The one in the picture is Aluminum with a 4060 motor.
    3,117
    Why change to carbon plate? The aluminum works as a heat sync.
    2,913
    Mike - I will check my 36" next time out, to see how warm the mounts get.
    Jun 2020
    7
    Jun 2009
    GA
    595
    The sheets from Hobbyking are actually really nice. I've been using all available thickness (1.5, 2, 3, 4mm) for years. They come in 200x300mm and 300x400mm sheets.
    Making your own also isn't terribly difficult. You could always mix a little fiberglass or kevlar in the layup.
