Need help with locating the correct size o-rings for the 3650 cooling can that OSE sells. It is the red can that comes with a 3674 Leopard motor. I need a size or a link for who sells them. OSE is out of stock.
Thanks in advance.
Thanks in advance.
If you can measure the old ones, you should be able to find a suitable replacement here: https://www.mcmaster.com/o-rings/hig...icone-o-rings/
Well that make sense but since I don't have those o-rings I need help. Lost at lake when I took apart because of a leak.
Sooooo any help is appreciated.
OK, try this: https://www.mcmaster.com/1173N028/ The I.D. is just a hair under 36mm, it's soft silicone, its hi temperature.
