Results 1 to 7 of 7
Thread: Parallel or Series first?
    Mar 2009
    AZ
    992
    Default Parallel or Series first?
    Just want some ideas on personal preference. Thx!
    Mar 2009
    OH
    1,580
    That's apples and oranges. One is increasing voltage (series) one is increasing capacity (parallel)
    Apr 2020
    CA
    701
    Quote Originally Posted by photohoward1 View Post
    I know what you mean...akin to asking whether a Toyota, or a Cessna, is better.
    Mar 2009
    AZ
    992
    I should have clarified..
    I?ve got 4, 6s packs @ 10,000 mah each. I?ll be running 44v for a total of 20,000 mah.
    Should I parallel the packs first for 6s, 20,000 mah then series for 12s, 20,000 mah or should I series first then parallel?
    Make sense? I can draw a diagram if you?re better with pictures.
    Jul 2016
    4,100
    I would do it whatever method results in the least amount of additional wire. How the packs are packaged inside the hull probably has more to do with the solution than anything else.
    Mar 2009
    AZ
    992
    That makes sense. I haven?t run a 4p setup before so I wanted to make sure I wasn?t making a mistake. Thanks doode!
    Aug 2008
    CO
    7,080
    I always do series then parallel. I did make a 4p adapter.. once. I agree with Ryan, least wire = lesser resistance= mo bettah
    "Look good doin' it"
    See the fleet
