Results 1 to 5 of 5
Thread: Water entering boat !
    Jan 2011
    497
    Default Water entering boat !
    Hi all built a 24 inch round nose Miss Thriftway hydro 12 years ago set up on 2190 kv 2860 Leopard running on 4s lipos recently i noticed substantial amounts of water in hull after 2 minute runs checked hull for cracks and checked plumbing system for leaks i even removed the flex cable and turned a bevel on the drive dog and re-packed the stuffing tube with Mercurys 2-4-C marine grease tonight after a 2 minute run there was 2 1/2 oz of water in the boat and i noticed a big gob of grease beside the flex hex i do not use a teflon liner just 3/16 brass tubing what are the chances the brass tubing could be wore out ! Where else could i look to resolve this problem ! Regards Andris Golts.
    Slip a piece of silicone tubing over the inboard end of the stuffing tub so that just a bit overhangs the end...enough to just touch the flex cable. Done correctly this eliminates water entering from the stuffing tube without causing excessive drag.
    Jan 2011
    497
    Hi Fluid there is already a piece of med size silicone fuel tubing zip tied to the inboard end of the stuffing tube i will replace it and check again good idea ! Thank you ! Regards Andris Golts.
    2,727
    A 24" hydro should fit in most domestic baths, tape it up, hold it underwater, and see where the bubbles are coming from.
    ca
    6,962
    Andris,
    This has always worked for me - seal the joint between the stuffing tube and the strut with shrink tubing (use silicone inside before heat shrinking to make sure it won't migrate)
