Results 1 to 7 of 7
Thread: Fusing
    Jan 2020
    NY
    20
    Default Fusing
    Is there anyway to fuse the ESC or motor to prevent it from burning up.
    Jun 2020
    NC
    233
    Yes but better is to stay within the rated specifications of the equipment or are you repairing a drive?
    Regards
    Hubert
    Jan 2020
    NY
    20
    Seaweed got wrapped around prop and must have overloaded. I thought the battery was depleted but it wasn?t.
    Jun 2020
    NC
    233
    Did it burn up the controller? U say Seaweed if this means you run in salt be sure to flush the cooling system with freash water afterwards. U can use W ater D ryer 40 to remove all the moisture when you are done flushing the system.
    Regards,
    Hubert
    Jan 2020
    NY
    20
    Generic term , I was running in a big pond.
    Jun 2020
    NC
    233
    Oh hydrilla. Did you burn up something?
    Mar 2009
    AZ
    992
    Quote Originally Posted by davidshaw57 View Post
    You can get cap banks to help with ripple current. Steve sells them.
