Page 3 of 5 FirstFirst 12345 LastLast
Results 61 to 90 of 123
Thread: Darin's UL1 Race Prep
  1. #61
    Jan 2009
    fl
    43
    I'm just about there... Need to apply some clear, and I have one more change I'd like to make, which is to put some brass tubing in for the water inlet and outlet. I prefer that over just running the lines through the hull. Should be a simple update.
    By the way... does anyone know what is backing up the motor-mount to hull screws in the hull?? Is it aluminum or a piece of wood... or nothing? I'm thinking I'd like to replace those screws (which appear to be small sheet-metal or wood screws) with some threaded 4-40 inserts or something like that...
    wow! i could sit here and just watch it all day!!
  2. #62
    Va
    4,670
    The motor mount is backed with aluminum sandwiched between FG. Hard to tell how thick the aluminum is but my guess would be about 4mm.
    IMPBA 20481S D-12
  3. #63
    WA
    8,335
    Quote Originally Posted by egneg View Post
    Just got word... it's 4mm thick wood... Inserts to come shortly... For those of us who just like to take stuff apart again and again and again!
    Darin E. Jordan - Renton, WA
  4. #64
    Va
    4,670
    I stand corrected. I was sure I saw metal bits but upon closer inspection it is indeed wood.
    IMPBA 20481S D-12
  5. #65
    WA
    8,335
    I think I'm going to throw up...
    I just shot a coat of clear on and the white paint crinkled all to hell... SAME freaking process I always use, but there it is...
    I'm going to set this aside for a few days to get hard, then start stipping off the white and start over with that...
    It was that, or just freaking throw it on the floor and CRUSH and STOMP the heck out of it!
  6. #66
    Jun 2008
    GA
    2,318
    Krylon clear can be sprayed over Krylon colors. What paint brands did you use?
  7. #67
    Jan 2009
    fl
    43
    wow! sorry to hear that....but dnt lose ur patience!
  8. #68
    WA
    8,335
    Quote Originally Posted by detox View Post
    Same brand and combos I've always used... Krylon base paint, with Duplicolor Clear Top Coat over it...
    I'm over it (bounce back quickly, eh??? )... I'll strip down the white part and try again...
  9. #69
    Jan 2009
    AL
    301
    I feel ya man....mine did the same in a couple of spots...I thought maybe I did something wrong. Then I thought ....this boat is going to be getting lots of battle scars anyway...the heck with it!
  10. #70
    Jan 2009
    AL
    301
    The worst is under the cockpit...rock on dude!
  11. #71
    Jun 2007
    5,190
    Darin, been there, I understand your frustration. Only one remedy...remove all paint!!!!
    The prevoius problems would have only been exagreated by the clear coat...dries very fast and no allowance for escaping gases from the previous paint problems
    Douggie
  12. #72
    Jan 2009
    fl
    43
    does ose sell lipos?
    whats a recommended power source for the ul-1?
    thanx
  13. #73
    Nov 2007
    6,927
    I'm pretty sure Duplicolor makes a clear acrylic enamel AND a clear lacquer. If you used the lacquer, it would probably eat the Krylon enamel. Might want to check that. My paints are at my warehouse and I don't have a chance to check that today. Also, Duplicolor colors come in lacquer (the car coded touchups) and the larger cans of acrylic enamel. I use the enamel all the way through on my paint jobs. I'm no expert though. I KNOW how frustrating it can be to have the bottom coat wrinkle! Been there. It's AWFUL!
  14. #74
    Nov 2007
    6,927
    Back in the 'olden days' when us old timey model airplane builders actually built and covered airplanes with silk and dope, it was almost impossible to get light colors to cover well. Yellow was the worst but white was no picnic either. The SECRET (shhhh) is to put on a coat of silver or aluminum first! Then the light colors will cover really well! Tadaaa!
  15. #75
    Nov 2007
    6,927
    You won't hear it rattle around for long. The magnets in the motor will find it soon enough! Cruuunch!
    I'd cover it!
    Yah... that would work... I'm half tempted to just leave it there and open... ALL of my other hydros are completely open in there... if it stays dry (all of mine do), then it's not an issue...
    .... until you accidently drop a screw or something in there and can't get it back out, and have to listen to it rattle around...
    ... I think I'll make a closeout panel for it!
  16. #76
    Nov 2007
    6,927
    I run two 2S Flightpower 25C 5000's. Great setup. I don't think Steven (OSE) sells lipos. Right now, Towerhobbies is selling the Flightpowers at dealer cost! (I know, I'm a dealer and getting hosed over by Tower!) There is a new series of Flightpower lipos coming out so I guess they're selling off the original series. These are absolutely incredibly good lipos! You can't go wrong at the current prices at Tower. I believe the 2S 25C 5000's are going for $89.99. Normally $119.99! Get 'em while they got 'em. You won't get any cheaper for a quality lipo. Sure, you can get the Zippy's from Hobby City but they ARE NOT as good a battery and with shipping won't be that cheap... AND if you have a problem, you gotta send 'em back to China.... etc. etc. etc.
    http://www3.towerhobbies.com/cgi-bin...?&I=LXWPB4&P=7
    Quote Originally Posted by killjoy781 View Post
    thanx
  17. #77
    Nov 2007
    fl
    664
    For what its worth, I got very frustrated spraying the new gen Krylon over prepared gelcoat and started using Testors Enamel and Model Masters High Gloss Clearcoat with very good results, Still have to let it marinate ( for lack of a better word) based on the instructions. Clearly, for abs or whatever the manufactures call plastic these days, Fusion is still a great product.
  18. #78
    Nov 2007
    fl
    664
    Sailr,
    That brings back fond memories....clear dope and silkspan...control-line... Sterling Ringmasters, Top Flight products..
  19. #79
    Nov 2007
    6,927
    Yeah, it wasn't the building and flying of the airplanes, it was the fumes! haha. I didn't think you were old enough to remember that Mike!
    Quote Originally Posted by highndry View Post
    Sailr,
  20. #80
    Nov 2007
    6,927
    Oh, I thought it was the Tamiya paint you liked. I bought one of those tiny little million dollar spray cans and didn't like it worth a hoot! ;-) Since the hatch is abs plastic, I thought maybe the Krylon would work good. The UL-1 is painted, not gelcoat. Might wanta think of that.
  21. #81
    Nov 2007
    6,927
    Mike, go easy when you clearcoat the decals I made for you. Too heavy and it will run the colors in the decal. Shoulda told ya that earlier!
  22. #82
    Nov 2007
    6,927
    Will the Model Masters clear work over the Krylon?
    Quote Originally Posted by sailr View Post
  23. #83
    Nov 2007
    fl
    664
    No, not Tamiya. I think that is for lexan. Yes, MM works over Krylon. The Fusion clear is more of a satin finish. If you want bright , use MM.
  24. #84
    Nov 2007
    6,927
    Thanks for the tip!
  25. #85
    Jun 2007
    5,190
    Tamiya make different paints for different surfaces. The TS series is what would be used for most of our applications, a synthetic lacquer. Yes, they are expensive but are of a very high quality. They have a specific paint for Lexan materials.
    The TS series is great because you can apply other paint types over the painted surface. Plus, no need for a clear coat which makes it easy to fix if you damage the paint suface.
    http://www.tamiyausa.com/product/cat...?main-id=60|80
    Douggie
  26. #86
    Jan 2008
    Mo
    2,716
    Yep, gelcoat should not be harmed but any spray paint. I thoought these were gelcoat but sounds more like painted. Is this true?
    Darin, fantasic paint scheem! It is very sharp man. Glad your boats don't run as good as they look! :)
  27. #87
    WA
    8,335
    Quote Originally Posted by Jeff Wohlt View Post
    Thanks Jeff... I think it's paint... After the initial debocal with the white, I stripped it off completely, using Citri-strip, and it even took the red paint off... was a mess.
    But, now, it's back in white, has the clearcoat on, and is mostly reassembled. I'm just waiting to get a water jacket for the motor.
    Will be interested to see how it performs... Hopefully at least as good as it looks...
  28. #88
    Jun 2007
    5,190
    Darin, I had to do the same procedure on a painted hull and it was a mess. Every other fix I tried without removing the paint just compounding the problems.
    I trust that all goes well with the next painting procedure.
    The original UL-1 suface is painted fireglass
    Douggie
  29. #89
    WA
    8,335
    Here is my advice to anyone wishing to customize the paint on one of these... buy a color you like, and add lots of decals/graphics... Much simpler!
  30. #90
    Nov 2007
    6,927
    It remains to be seen if my paint is gonna hold up to tape! All I painted was the hatch and cowl. I'm in the same boat as you...waiting for a water jacket. I gave up on the POS one that comes on the boat. Also had to do your major surgery on the right sponson where the fin bolts on. Mine came with the sponson pretty badly split open already. Just finished that job. I'm going to use the foam you suggested (it just arrived today) and pour it in several places in the boat. I just don't like how flimsy the hull is. Now I'm trying to find the little 1 oz medicine cups to measure that stuff. No luck at Walgreens!
