Page 3 of 3 FirstFirst 123
Results 61 to 66 of 66
Thread: Outerlimits SV43 build
  1. #61
    any updates? looking forward to seeing this thing completed!
    DYMotorshop 29er (BUILD) | ProBoat BlackJack 24 (52.2mph) | ProBoat Stealthwake 23 (31.9mph) | Noodle Recovery Barge (6.6mph) | ProBoat JetJam (BUILD)
  2. #62
    4,131
    Boat is finished. Haven't had much time to tune the setup and figure out the right prop. I might need to swap for a lower kV motor so that I run run a larger diameter prop. I have an 800kV 5680 in my Zelos 48G conversion that I might try this weekend.
  3. #63
    4,131
    Swapped in the 800kV motor this afternoon and bolted on an ABC2315 prop. A lower speed potential, but the original setup was completely unusable so fingers crossed.
    PXL_20210912_192602102.jpg PXL_20211008_215000761.jpg PXL_20210912_191601109.jpg PXL_20210912_191651291.jpg
  4. #64
    man i just love the way this thing looks. what made the original setup unusable?
  5. #65
    4,131
    Quote Originally Posted by autolex View Post
    It was more power/speed than the hull could handle. It ran much better on the 800kV motor, but still a lot of work to keep it on the water and no improvement in the turns. I'd scrap the entire project if the hull wasn't the best looking V-bottom from the waterline up, in my opinion. I think it's going to get sent to the body shop this winter to have the steps smoothed over. It can't get any worse.
  6. #66
    I just started a thread on a 29.5" that i'm going to be building, taking a lot of your reinforcement ideas and running with them. Hopefully i've picked a decent hull to start with.
