Results 1 to 5 of 5
Thread: Miss Geico 36 twin strut adjustment
    Nov 2016
    44
    Default Miss Geico 36 twin strut adjustment
    I m using Giant Power 6000 70c-140 x4 batteries and Daboata 1815 props
    The stock setting is 2.5mm wondering where I should be at with this set up
    Dec 2010
    3,120
    Quote Originally Posted by Fixitguy1 View Post
    Is that 2.5 up or down,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, angle I presume ???????????????????
    Nov 2016
    44
    That’s 2.5mm down for the stock setting
    One respond was push batteries all the way up, drop the strut all the way down and hang on
    Feb 2017
    na
    726
    That?s 2.5mm down for the stock setting
    Sounds like someone is trying to give you a setup to run on the Gulf of Mexico....The stock setting with batteries in the normal position sounds pretty good to me, if I was running on flat to semi flat water.
    Nov 2016
    44
    Yeah I think that guy showed a picture of that boat after it flipped back over front and cart wheeled
    I’m going to run it with the stock props and stock setting first to see what I have
