Results 1 to 8 of 8
Thread: First time modding a MambaXLX . Need input thought.
    Oct 2008
    ca
    1,941
    Default First time modding a MambaXLX . Need input thought.
    Scratched the oil bath idea and figured water cooled metal pulls heat better than oil. Everything is bonded with JB weld and I was careful to not short circuit the board by having a cured layer on all part that touch the board. I?m just curious if I completely destroyed this by possibly hindering its timing . I have but power to it and no explosive behavior so far. This thing has lots of heat pulling capacity for sure now only if it works correctly
    B1E98509-85D9-49FB-9602-6A8C375DE8F6.jpg5FE3E945-B674-4B22-8C09-F5A3696FCDB8.jpg527B6346-37A3-46F6-9F2D-4DA72D6B9E9E.jpg
    --Albert Einstein
    2,727
    Is JB Weld not conductive? I haven't used it myself, but have heard it uses steel as a filler.
    Jul 2007
    or
    1,088
    JB weld is definitely conductive. If you bridges the power input buses or the three motor phase outputs you probably killed it.
    From the first pic it appears you have the JB weld crossing "+", "-" and at least one output phase.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
    Oct 2008
    ca
    1,941
    Quote Originally Posted by raptor347 View Post
    --Albert Einstein
    Oct 2008
    ca
    1,941
    No it is non conductive https://www.jbweld.com/faqs
    --Albert Einstein
    Jul 2007
    or
    1,088
    I stand corrected. It should be fine then.
    I usually just strip the case off, solder copper tubes to the power buses and re-conformal coat it.
    NAMBA FE Chairman
    Oct 2008
    ca
    1,941
    I’d like to see pics of that someday. I probably went over kill lol
    --Albert Einstein
    Oct 2008
    ca
    1,941
    Default It?s alive
    --Albert Einstein
