Results 1 to 4 of 4
Thread: Problems to put the 8S Lipo's in MHZ 114
    Apr 2020
    IB
    10
    Default Problems to put the 8S Lipo's in MHZ 114
    Hello to all, I'm trying to put the 8S batteries in MHZ 114, and is not easy, what do you think about?
    Aug 2015
    fl
    22
    Hi Rafm !
    I have a Turnigy Grafene 6 S 5000 in each Sponson in front of the Motors and it works perfect !!
    4,119
    You will likely need to trim back the lip on your canopy opening. I would not remove the entire lip, only a portion, so that you can still run a neoprene hatch seal.
    FR
    2,096
    Try 4S - 8000mAh in each transon, serial.
