Results 1 to 3 of 3
Thread: 8s ESC Recommendation
    Jun 2010
    Mi
    738
    Default 8s ESC Recommendation
    Team,
    I want to build a rigger with a TP2935 8y, 1680 KV motor I have. I would like to run it on 8S, (I know, its a lot).
    Here is the hull:
    http://ecomaster.torgg.com/collectio...roduct/hydro-1
    Question is, what is ESC should I get? I dont need a lot of amps.
    Looking for a light unit, perhaps with a BEC if available.
    I was considering a Flier 8S, 120A model with a BEC.
    https://www.ebay.com/itm/120A-Boat-M...53.m1438.l2649
    4,100
    I wouldn't recommend a Flier ESC to anyone after the trouble they gave me. Hobbywing makes a 150A HV ESC, so does Swordfish. Not sure what your budget is like, but MGM makes a compact 25035 in the X2 Lite series. You'll probably need to un an external BEC circuit.
    2,726
    Nice hull. You'd save a chunk of change on the ESC if you dropped down to 6s, and it would still be pretty HV considering it is normally a 2-3s boat.
