Results 1 to 5 of 5
Thread: Aero-Naut Air Marine Special build.
    Feb 2011
    RI
    25
    Default Aero-Naut Air Marine Special build.
    My first time with a stick built kit, I love the look of this hull when finished.
    First thing I did was to sand all the parts flat in the sheet, after that lots of edge sanding and needle file work once I broke out the pieces I needed for that particular step, not a problem with Aero Naut quality, just my anal nature.
    Feb 2011
    RI
    25
    Next is to glue up the keel and start attaching formers, keeping everything square,
    my building board hadn't arrived yet so i'm working on the granite counter in the kitchen.
    Yes my wife is very understanding.
    Feb 2011
    RI
    25
    Next is the bottom panel and the sponsons, the parts were cleanly cut by laser and don't need a lot of touching up.
    Feb 2011
    RI
    25
    Once the bottom is finished you can cut off the building tabs and epoxy resin the inside.
    This was the worst part so far, I learned how to thin and mix the epoxy on this site,
    Thanks Guys!
    Feb 2011
    RI
    25
    More to come,
    I ordered my ESC and steering parts from OSE, should be here by Friday.
    This will be the power for the boat, also made by Aero Naut.
