Results 1 to 4 of 4
Thread: Prop ideas
    Sep 2014
    Mi
    99
    Default Prop ideas
    I have a ProBoat Sonic 36. All stock except for OSE upgraded cable and OSE dual water pickup rudder. I will be running 2-3s Lipo's in series. I want to upgrade the prop from stock, but dont want to overload the current setup What is the next step up choice of props to install?
    Apr 2020
    701
    I don't have an answer, but I will be paying attention to this. I just bought the same boat from Steve, and could use an answer to the same question...tho, my plan is to start on 2x 2S, and, once I've had the chance to replace the ESC & prop, then run 2x 3S.
    Sent from my SM-N975U using Tapatalk
    Mar 2015
    166
    Have a look at this thread for some Sonicwake prop ideas:
    https://forums.offshoreelectrics.com...986#post743986
    Apr 2020
    701
    Quote Originally Posted by Capt'n Crash View Post
    Thanks for the info...and the info you also posted in there (since I was already posting in that thread, even tho I know this reply was primarily directed towards the Op).
