Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 UL-19 cutting off problem - Offshore Electrics Forums
  • Toddly
    • Mar 2020
    • 12
    Hi can someone please help me with my ul-19 I replace the stock motor with the tp40 30cm series motor 3 900kv I believe and I believe the TP specs on that motor 140 amps and the stock Dynamite ESC in that boat is 120 amp is that why the motor keeps cutting off and on off and on when it warms up after a couple minutes the guy from TP asking if I s?t the current cut off and what number I set it at I do not even know nothing about that can somebody help me out with this problem please??Thank you....
  • fweasel
    master of some
    • Jul 2016
    • 4281
    Hi, welcome to the forum. You only need to post your question once. Someone with an answer will find it, even if its not in the best location.
    Let me understand this, you replaced your stock motor with a TP4030 3900kV motor and are running the stock 120A ESC, correct? What voltage are you using, 2S, 4S, 6S? The kV on that motor is WAY too high and is the fundamental problem. The stock motor was 2000kV, already near the limit for 6S and better suited for 4S. You've practically doubled it.
    • Toddly
      • Mar 2020
      • 12
      Yes I'm running a 6s with the stock 120A esc but I've ordered a sea king 180A V3 esc
      • Toddly
        • Mar 2020
        • 12
        Yes I'm kinda new to this boating thing but I'm loving it sorry about posting it to many times and thank you for your help...
        • fweasel
          master of some
          • Jul 2016
          • 4281
          Ok, no worries, we've all been there. kv rating on a motor is the RPM it will spin per 1volt. kv x voltage = unloaded RPM's. In general, you choose the motor's kV based on the voltage you plan on running, as well as other factors like hull, running conditions... and the list goes on. Usually, 6S is run in the 1600-2000kV range depending on the application. 3900kV would be best suited for a 2S setup. That is the wrong motor for your boat.
          Why did you replace the stock motor? It's actually a pretty good match for that boat.
          • Toddly
            • Mar 2020
            • 12
            Just wanted it to go faster and I just got done running it and my meter said top speed 109mph
            • Toddly
              • Mar 2020
              • 12
              I'm not sure how accurate that thing is I'm going to go running again to see if it says the same miles per hour so will a 180 amp ESC fix it?
              • TRUCKPULL
                • 2971
                You said above that you bought a CM style TP motor??
                Do you know that the MAX run time is 5 sec. in a boat, or it will over heat and shut down.
                For a Rc boat - CM motors
                -1700Kv Version, 28.0v maximum for 5 seconds or less.
                -2200Kv Version, 22.2v maximum for 5 seconds or less.
                -3200Kv version, 14.8v maximum for 5 seconds or less.
                Larry
                • Toddly
                  • Mar 2020
                  • 12
                  TP specs are saying it has a 10 second max run time so what does that mean I can only full throttle it for 10 seconds??
                  • Toddly
                    • Mar 2020
                    • 12
                    Well today it died I heárd the fan running but it was just going beep, beep, like the receiver wasn't getting a signal then I open the canopy and out come the smoke it fried my servo along with the esc I turned it then on and the motor still worked but the capacitors looked burnt one the esc I really hope the seaking 180A V3 can handle the TP 4030 CM motor????..
                    • Toddly
                      • Mar 2020
                      • 12
                      • Toddly
                        • Mar 2020
                        • 12
                        • Toddly
                          • Mar 2020
                          • 12
                          Any ideas what caused that
                          • fweasel
                            master of some
                            • Jul 2016
                            • 4281
                            You cannot run a 3900kV motor on 6S. That's what caused this.
                            The original motor was a D wind and had 7.5* timing set on the ESC at the factory. I cannot find a published wind configuration for the TP4030CM on TP's website. It's either D or Y, which means you've got only a 50% chance you're running the correct timing on your now fried ESC. You're lucky you didn't burn the entire boat down. I would take a deep breath, order parts intended to be used together in a hydro of this size, and start over again.
                            • TRUCKPULL
                              • 2971
                              10 sec. is in a car. 5 sec in a boat.
                              Look at the CM specs for a boat right here on Offshore Electric.
                              Larry
