Results 1 to 9 of 9
Thread: Tp 3630 1950kv
    Nov 2007
    fl
    1,260
    Default Tp 3630 1950kv
    Looking for some suggestions. I recently swapped in this motor so that I could use the leopard on a different hull. I have had one test with the boat and found it to be substantially slower even when I went up to the next size in prop.
    The original setup was a leopard 3660 2050 kv with an abc 1715
    I ran the tp with a 1717
    I have been trying to figure out what timing is recommended for these motors. I?m going to be testing more on Friday and hopefully I?ll find a solution but I am obviously looking into recommendations
    My test was roughly the equivalent of a heat race. I found the motor to be about 145 degrees, esc was 105, and batteries about 92 degrees.
    Aug 2010
    uk
    2,887
    Your TP3630 - 1950kv is a D wind motor, needs low timing 0 - 5 degrees. The 1717 prop has a lot of pitch for this motor so may be pushing temps up.
    Nov 2007
    fl
    1,260
    thank you Martin. I appreciate the feedback. I will be verifying the timing when I get the program card in my hands on Friday and I plan to play with more props as well
    Sep 2012
    Tg
    1,438
    The next size prop is a 1716, the UL19 and Zelos prop.
    Nov 2007
    fl
    1,260
    It is a 1716. I fat fingered my phone
    Nov 2007
    fl
    1,260
    Changed the timing in the esc and it helped the motor quite a bit
    Aug 2010
    uk
    2,887
    Quote Originally Posted by obrien View Post
    That is good to hear.
    ma
    8,693
    What timing did you end up with?
    Steven Vaccaro
    Nov 2007
    fl
    1,260
    0 degrees
