Results 1 to 7 of 7
Thread: Q cat twin ESCs
    Mar 2018
    109
    Default Q cat twin ESCs
    I'm building a aeromarine 36" avenger twin course boat. I want to run TP 4050s 1700kv, ABC 1814s or 1815s on two 6s 5000mah packs. Will 200amp ZTWs handle that set up or would I be better off with Swordfish 240s?
    4,117
    The ZTW 200's will do fine.
    Mar 2018
    109
    Thanks for responding. Going with the 200s will save me almost $200.
    2,910
    I run the 4050's 1570KV - 180A Seakings (Only $120. each). 1815 props
    77MPH in race setup
    6,190
    77MPH in race setup
    And that's the fastest oval Q cat I've ever seen.
    Noisy person
    2,910
    Terry
    When you go to Florida, you will see some more.
    Have your video camera ready.
    Mar 2018
    109
    Terry
    I'll go with the 1814s with the 1700kv motors. I'm gonna need to run pretty fast to keep up with the other Q cats in the club. Mid to high seventies should work since the Avenger will beat them in the corners. I was itching and already pulled the trigger on 200amp ZTWs and 4050 1700s. Thanks for responding.
