Results 1 to 3 of 3
Thread: H&M No step 4
    May 2009
    UK
    1,018
    Default H&M No step 4
    Anybody experienced with this hull?
    Just picked a complete one up built with a Tp5850 1000kv, Mbp-rc 300 amp esc designed around 10s...
    Sufficient reinforcement in the hull also
    I also have a Lehner 3060/6 1167KV which im going to drop in... its only marginally longer and wider than the Tp5850
    the boat ran about 65mph on a 5850, i guess with 10s on the 3060 it will be closer to 70 with a Prather S235 which is what its currently running...?
    I don't know much about the MBP esc, would i be safe to prop up to a s240? probably wont need too?
    Should fly...
    Uk SAW record holder
    Nov 2008
    Ql
    3,169
    I ran one back in 2012 when I was a bit of a rookie at this FE game.
    Here's a link to a thread, if it is of any help.
    It shows a few pics & videos. Also the a couple of problems, along with the fun.
    https://www.rcgroups.com/forums/show...Step-4-36-mono
    Cheers.
    May 2009
    UK
    1,018
    Hi, i did actually find that thread and give it a read... some of the info i was looking at is blocked / lost but...
    Ill be home in a few weeks to start tinkering on with it and getting it going... i do have a lot of power installed for the size of boat so could be some interesting results, it is suitably reinforced...
