Results 1 to 7 of 7
Thread: seaking 180 lvc question
    Oct 2016
    pa
    476
    Default seaking 180 lvc question
    for those in the know .this is my first sk180
    when it hits lvc it does not recover?
    i hit lvc pretty early on today .i was stuck in half throttle mode thereafter . these things dont reset?
    even my cheap flycolor 150 would recover after lipo voltage came back up .
    sorry if this been covered before ,i didnt feel like searching .
    Jul 2016
    4,131
    pretty sure that ESC has to be shut off and turned on again to reset the LVC. Not to mention, that ESC is known for a flaky, and overly sensitive LVC circuit. I recommend you disable it all together and time your runs instead, aiming to bring the boat back with the cells near 3.8V
    Oct 2016
    pa
    476
    yeah i was afraid of that ,should have known better to buy one .
    Jul 2016
    4,131
    ESC is great aside from that one issue, and there's no reason to replace it. LVC is really a false crutch anyways.
    Jan 2009
    ct
    1,101
    Not a LV cut I am pretty sure. It is an over heat issue. I had the same issues with these in my H&M T-4 hydro I just built and slowly cured it by adding more water flow, better cooling heat sinks {dual} and one step smaller prop. I now have it running just as fast and no cut off ever. Great little ESC that kicks ass every time for the money and is water proof too!
    Mar 2017
    or
    236
    many of us experienced the LVC issues.....sadly I bought 3 of these seaking 180 at the same time ....then learned about the LVC issue
    caused me the same problems on all 3 boats......I had to turn all 3 off
    In retrospect the LVC is a false sense of security ...know your equipment and time your runs
    Mar 2015
    ON
    166
    +1 on know your equipment and time your runs. I have several FE boats and do no rely on the LVC for any of them.
