What a gorgeous build! Thanks for sharing.
Don?t worry about no on/off switch, many ESCs don?t have them. They arm after connecting the pack. On/off switch or not, treat every FE boat with the pack connected like a loaded gun.
Your boat weight is fine, that is a powerful setup you have. You may find the 40 and 42mm props too small to push the boat efficiently, most boats that size use larger props and lower Kv motors. I can?t tell how much of the prop arc is near the surface, that effects the prop efficiency and a larger prop may be better. For best performance you may need a 45-47 mm prop, but check the motor and ESC temps often regardless. Try to minimize part throttle running, that heats up the ESC faster than full throttle running.
