Results 1 to 2 of 2
Thread: 10th scale hydroplane wiring
    Nov 2018
    27
    Default 10th scale hydroplane wiring
    [ATTACH=CONFIGDBF4F853-A005-4A49-886C-B0A446FCC830.jpg]167840[/ATTACH]hi there I built this boat I have all the electrical components motor esc receiver servo battery installed i need a wiring diagram I am not sure what on off switch and fuse to use
    Nov 2008
    Ql
    3,030
    In most fast electrics we don't use a switch or fuse in the power system.
    Do you intend to race in the 1/10 scale class or is this boat just for fun?
    The 1/10 scale racers should be able to give you a good setup for your boat. I'm not sure of the requirements over there in the States.
    Here's a basic diagram, showing 3 variations. It depends if your ESC has a built in BEC or not.
