Results 1 to 4 of 4
Thread: HobbyWing Marine 30a and Outrunners
    Apr 2016
    mi
    16
    Default HobbyWing Marine 30a and Outrunners
    Will this esc run high pole count outrunners trouble free?
    https://www.offshoreelectrics.com/pr...seaking-30a-v3
    AZ
    7,633
    I have not been able to find the maximum pole/rpm for this ESC, but most will handle 200,000 rpm for a two-pole motor. What motor (poles and Kv) and voltage are you planning to use?
    Apr 2016
    mi
    16
    High pole (9 and up) outrunners. Reason I ask, when I tried there 120a on the recoil 26 outrunner (14 pole) it would not run right.
    AZ
    7,633
    That would translate to over 200,000 in 2-pole rpm, so if 200,000 is the limit that could be a problem. Another could be the timing - what is the ESC timing advance?
