Results 1 to 2 of 2
Thread: zelos36 good prop
    Mar 2019
    AZ
    27
    Default zelos36 good prop
    want to upgrade my props on my zelos36 what is the best for quick lift and better speed have been reading about cuped props ??? anone used them
    Jul 2016
    2,953
    Simple upgrade is a pair of Octura x447 props which will bump you up to about 70ish on a stock boat with good batteries. The ABC 1715 props are a step up from there, more speed, less run time. You can go up to the ABC 1716's for really fast passes, but I wouldn't recommend them unless you have the newer 3831 motors, and they're only good for a few straight line passes than back to the dock before things overheat. PM member Dasboata, he can get you setup with whatever prop you choose.
