Results 1 to 3 of 3
Thread: Miss Geico 36 twin
    Oct 2019
    14
    Default Miss Geico 36 twin
    I?m wanting to try some 3 blade CNC stainless props on her. Anyone have any suggestions.
    Running
    2-3s 9000mah in series to 6s with splitters.
    2- dynamite 120a esc
    2- dynamite 4 pole 1900kv at 11deg timing.
    Mar 2019
    30
    https://www.ebay.com/itm/645-3-3D-Pr...0AAOSw38Vbp-tM might work! im looking to get these on my Zelos and im pretty sure theyd work - look pretty too, very well made props I have the same sellers polished and sharpened prop for my sonicwake and it gets up on plane mush faster!
    Also - how are you liking that oxidean tubing? did you have to put different sized inlets/outlets to make sure they fit? or is it the same inner diameter as the stock tubing? Im looking to get colored tubing and I want to make sure i get the right ones!
    Mar 2020
    IN
    I recently put the oxidean marine tubing on my geico 36 and it fits but due to larger inner diameter it requires some small zip ties to make sure it stays!! I also drilled stock fittings inner diameter slightly larger to promote better cooling as well..
