Results 1 to 3 of 3
Thread: Stuffing Tube Installation
Hybrid View
    Jan 2020
    NY
    20
    Default Stuffing Tube Installation
    I am using a 1/4 ? stuffing tube in a flex shaft application. I want to use a sleeve that penetrates the hull. What size sleeve is required to fit over the stuffing tube snugly.
    For water tightness I will solder where they overlap , this will allow me to have the ability to remove the stuffing shaft for replacement and not effect the hull penetration .
    Your input would be appreciated.
    Jul 2016
    4,119
    If it's KnS brass tube, 5/16" is the next size up that will slip over a 1/4" tube. I do the same thing with sleeves to make it easier to change tubes in the future if necessary. No need to solder. A light smear of silicone as the inner tube slips into place is all that's needed to keep the water out.
    Jan 2020
    NY
    20
    Thank you for the info the silicone is a much easier method.
