Results 1 to 5 of 5
Thread: Recommendations for someone to finish a build
    May 2009
    UK
    1,018
    Default Recommendations for someone to finish a build
    Long story short i have a 90% finished hpr115,
    every few years i come back to it, buy a few things get side tracked.
    Im located in the UK and there isn't a fast electric scene...
    I can get the boat to Florida for free and then post it anywhere stateside from FL,
    I'm looking for someone to finish off the final details, setup and tuning basically..
    I know it's not really an incentive as not much money to be made on a 90% built boat but willing to pay handsomely for any work / setup hours needed...
    I would prefer someone with previous HPR experience and do understand things go wrong
    Setup is as follows, HPR115 carbon with full HPR kit
    Lehner 2250/7
    AS26-XXX
    SLS 40c Lipo - 6s 5000mah
    x447 andy brown tongue cut
    futuba 4grs
    the esc, battery and remote are all brand new, the motor's are used.
    Im budgeting maybe $1000 to get it completed, i've had the thing such a long time and its such a shame i don't get any use out of it, I'd like it to be somewhere near the 80mph mark and depending on the builders experience willing to take suggestions on one day going north of 100.
    I've had lots of expert advice over the years on building it but even last time i finally thought it was all set on the water she had some water ingress and cut out... i've had experience in the past of seeing a boat go up in flames due to my inexperience and theirs a lot more $$ invested in this..
    Uk SAW record holder
    Mar 2011
    BC
    7,631
    I would reach out to Scott (tiqueman), Shawn Swain, or maybe Ryan? (Fweasel). Post would probably kill things getting it to me in Vancouver Canada. But I could likely find time within a reasonable time frame
    May 2009
    UK
    1,018
    Thanks for the suggestions, I’ll fire some pm’s off,
    I might be very lucky and found a very experienced builder here in Europe.. could finally be the time for this boat.
    Nov 2012
    De
    356
    Quote Originally Posted by vvviivvv View Post
    Thanks for the suggestions, I?ll fire some pm?s off,
    Hi Liam
    What do you have left to finish? I can probably help you out finishing the boat and getting a final setup done, they only problem will be timing as I?m moving house shortly and setting up a new work shop.
    Steve
    May 2009
    UK
    1,018
    Looks like the boat is going to Germany end of the month.. thanks for the suggestions :)
