Results 1 to 5 of 5
Thread: Can SSS 3674 2075Kv Motor run 6s?
    Aug 2019
    SC
    14
    Default Can SSS 3674 2075Kv Motor run 6s?
    Oct 2016
    pa
    476
    this link here says max voltage is 30 v so in theory yes it can .should you though is another story .
    https://tflnorthamerica.com/product/...or-36742075kv/
    Mar 2015
    ON
    166
    Kv is a little high for 6s. It would run best on 4s.
    Aug 2015
    VA
    435
    We run twin SSS 3674 2075 on a Zonda with 120 amp ESC's and 3 blade 48 CNC props. We keep run times around 3 minutes and in runs fine.
    AZ
    8,010
    What does the OP want to put the motor in? Running a 2000+ Kv motor on 6S means that prop choice will be critical, a little too much and - pow. Too, this is a relatively small motor rated to just 73 amps max. You can load it more, but it will get hot so limiting run time will be important. It won’t spin a big prop efficiently so large single motor hulls are probably not a good idea.
