Results 1 to 17 of 17
Thread: What to use?
    Dec 2019
    ns
    19
    Default What to use?
    I?m running a 3/16 flex cable just wondering what is the best thing to use between drive dog and strut gap??
    Feb 2018
    PA
    330
    Normally just a gap between drive dog and strut...no washer or bushing.... Cable shrinks a bit when under load, You don't want the drive dog hitting the strut at all.....
    Jun 2011
    789
    https://www.offshoreelectrics.com/pr...s%2810+pack%29
    Put 2 washers on and a bit of grease and the drive dog will never hit the strut.
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    Jul 2016
    4,116
    I prefer to just run with an appropriate sized gap, and no washers.
    Sep 2007
    NC
    2,783
    The gap for a collet set-up should be set based on the length of cable. For short cable lengths, smaller gaps around 1/8" are OK. Longer cables should have a larger gap, start with 3/16".
    Look for signs of contact between the end of the strut and drive dog and adjust as needed. Ideally, you do not want too much gap.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    Dec 2019
    ns
    19
    Thanks guys for feedback I also noticed it takes in a bit of water between gap and runs up the back of strut through the stuffing tube and in the boat any ideas how to stop it
    ON
    9,400
    Than you for confirming something I have pondered for years!
    Feb 2008
    GB
    2,727
    A piece of silicone water tubing or heat shrink tubing over the stuffing tube on the inside of the boat so it lightly touches the flex or wire, will stop most of the water coming up the shaft.
    Oct 2019
    NY
    4
    marine grease on the cable
    Aug 2015
    VA
    435
    Quote Originally Posted by tales View Post
    Marine grease works really good for me sporting around on the water.
    Nov 2008
    Ql
    3,169
    Beveling the front edge of the drive dog also reduces the water being forced up into the stuffing tube.
    The bottom one is beveled. The top one is not.
    AZ
    8,010
    Cool
    Because the cable will shorten differently in each application due to length, stiffness, clearance in the stuffing tube, and load it is not possible to determine a perfect gap. Using washers between the strut and drive dog with no gap means that the cable will be in tension, causing excess drag and stress on the cable. As Tyler mentions above, a minimal gap is best, but you must not have the drive dog touching the strut.
    I seldom have used one, but as mentioned a short piece of silicon fuel tubing on the inboard end of the stuffing tube can virtually eliminate water intrusion from the drive line, see below.
    ca
    6,962
    Quote Originally Posted by 785boats View Post
    Well I just learned a good tip - Thanks
    In exchange , here's another method which works well to keep water from entering the joint between the stuffing tube and strut - cover the joint with siliconed-inside shrink ; has substantially cured water intrusion for me :
    Here I had to notch the strut to allow the shrink to slip on :
    Mar 2015
    ON
    166
    I had a similar problem with one of my Pursuits with water entering the stuffing tube. All I had to do to solve the problem was change my method of greasing. After greasing the flex shaft I would put a couple pumps of grease from the gun in the stern end of the stuffing tube before inserting the shaft. Never had a problem after using that method. You do have to make sure to clean the end of the shaft of any grease before inserting it into the collet.
    Aug 2010
    uk
    2,887
    As Paul has shown the bevel on the front of the dog helps prevent water being forced into the strut/stuffing tube. I have also been using this method for a long time now along with other usual mods to prevent water coming up the stuffing tube into the boat.
  16. #16
    Mar 2011
    BC
    7,629
    Quote Originally Posted by properchopper View Post
    Ditto Tony, can?t believe I didn?t think of it or discover it on here before.
    And BTW, interesting rudder in the last pic you posted
  17. #17
    ca
    6,962
