Assuming you use the existing stuffing tube location and mount the motor where the engine used to be you can try mounting an ESC alongside or even underneath the motor depending on which ESC you go with.
Depending on the lipos you choose you may be able to place the ESC on top of the batteries.
As Fluid mentioned, water tight is crucial and I always recommend stuffing flotation into any nook and cranny to improve buoyancy in case the cowl does come off.
Tyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
