Results 1 to 13 of 13
Thread: "Old Wood" 3.5 Tunnel Restoration and FE Conversion
    WA
    8,335
    Default "Old Wood" 3.5 Tunnel Restoration and FE Conversion
    Had this "Old Wooden" 3.5 Tunnel sitting around for some time, and I've purged most of my other projects, so I figured I could tinker on this a bit over the coming months to hopefully make it useful again.
    Not even sure what it is, but whoever built it did so with a LOT of skill and care. Pretty nice lines, well made, etc.
    First step was to sand... and sand... and sand... sand some more... and I still have a little sanding to do.
    Going to do some structural upgrades, and then update the layout to support an FE setup. Not for racing, just for fun. It's a TINY boat... 24", so I'm going to set it up for a high-revving 2S setup, which will allow the use of appropriately smaller props and will also keep it light.
    Small_OPC_001.jpg Small_OPC_003.jpg Small_OPC_004.jpg Small_OPC_007.jpg Small_OPC_012.jpg
    Darin E. Jordan - Renton, WA
    WA
    8,335
    WA
    8,335
    Took a break from the sanding to do some machining on the K&B 3.5 Lower for the FE conversion...
    K_n_B_Lower_FE_001.jpg K_n_B_Lower_FE_002.jpg K_n_B_Lower_FE_003.jpg K_n_B_Lower_FE_004.jpg K_n_B_Lower_FE_005.jpg
    WA
    8,335
    WA
    8,335
    Teflon in these is draggy... so I'm replacing it with a brass stuffing tube, like I do in all my lowers. Propshaft will be replaced with a HyperformanceRC 3.5 unit, which has a longer propeller shaft and is supported by better bearing surfaces.
    Starting to add in the bulkheads and other structural mods to support the FE Conversion...
    Jun 2009
    2,539
    At first glance I thought it was a hotshot, but after a few more pictures......WHAAAA? WHAT IS THAT?? Awesome mods on the 3.5!
    Feb 2018
    PA
    330
    Very cool .....I'm resurrecting and old Dumas 36 inch Dragon Fly shovel nose hydro......nitro inboard to FE.....rare hull I'm told...very well built and stored..never been wet.... Should be interesting......
    WA
    8,335
    Couldn't help myself. No sense in doing this if it's not going to look good!
    Polished up the now modified K&B 3.5 lower...
    7,630
    Great job Darin! Leg looks Uber cool
    Sep 2007
    2,783
    Darin, that's the tunnel I gave you years ago right?
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    WA
    8,335
    It is! Figured it was time to make it look like it belongs on my shelf. :)
    Sep 2007
    Co
    3,915
    After I get my shop set back up I hope to redo some old projects, looks like you are having fun. I am having a problem finding most little things in my garage, they are in a box some where. LOL
    Randy
    BBY Racing
    4,119
    looking good
