Results 1 to 10 of 10
Thread: ESC Recommendations
    Jun 2012
    Ca
    3
    Default ESC Recommendations
    I have a 49" aeromarine donzi that I am converting gas to electric, I plan to run 8s only in this boat. I have this motor
    https://www.ebay.com/itm/56112-B-Bru...Td40mNq2gw9bmA
    KV: 780KV
    Max power: 7350W
    Poles number: 4
    Max voltage (LiPo): 9S (780Kv)
    Max Amps: 195A (780Kv)
    No load current: 2.8A (780Kv)
    Diameter: 56mm
    Length: 112mm
    Propeller will be octura x457.
    Will a Swordfish X+ 200A ESC work with this setup? My goal is 50MPH.
    Any suggestions appreciated.
    Mar 2011
    BC
    7,631
    I would run a SW 240 myself. There shouldn?t be anything wrong with 8s in that boat. Just make sure you run 8s2p, or 8s 10,000mah or more.
    BTW, is this your first FE boat?
    Shawn
    Feb 2008
    GB
    2,733
    8s in a 49 inch heavy gas converted mono smells like unnecessarily high amp draw to me, unless you are confined to 8s by class rules I would use a higher voltage to reduce the amp draw at a given speed.
    Mar 2009
    OH
    1,585
    Goal is only 50. He won?t be pulling a lot of amps. That set up with the right prop should work.
    AZ
    8,010
    The x457 prop is very small for that setup, amp draw should be relatively low. 8S gas boats with 800-850 Kv motors normally run props in the 65-70 mm range, that’s a 50% increase in the thrust cone area. How efficient that prop will be on such a large draggy boat is the real question, will it be able to reach 50 mph? All those strakes should help. I assume it is a full surface drive boat.
    Jun 2012
    Ca
    3
    This is my first large gas to electric conversion boat, Im coming from 1/5 scale electric cars.
    I am limited to 8s due to motor and would prefer to stay at 8s so I wouldn't have to purchase any more batteries.
    Which prop would you recommend then?
    Thanks.
    Mar 2009
    OH
    1,585
    Start with the 457. See how it goes.
    I think you will be surprised.
    ON
    2,918
    What batteries do you have now?
    # of cells, -- mHa, -- "C" rating, --- Make?
    Larry
    Jun 2012
    Ca
    3
    4x 4s 7200mah gensace 70c in 8s2p 14400mah total
    Mar 2011
    BC
    7,631
    Quote Originally Posted by photohoward1 View Post
    Agreed Howard, I think I may only have a 455(or less) on this 45” Dumas (600kv 12s)
