Results 1 to 5 of 5
Thread: Prop suggestions 4082
    Nov 2019
    NJ
    8
    Default Prop suggestions 4082
    Looking for prop suggestions for my new setup. I have a leopard 4082 2000kv on 4s with a seaking 180. This is on a 32 inch hydroplane. I have read that these motors can turn larger props but i'm quite ignorant, the selection is overwhelming Maybe the x447? Any help would be much appreciated! Thanks
    Mar 2017
    or
    236
    I run 45mm or 46mm with that setup the 46mm I use is cut down and balanced and for the occasional 6s SAW run
    Jun 2011
    789
    I would recommend an M445. M545 or ABC 1816 to start.
    Mic
    Mic Halbrehder
    IMPBA 8656
    NAMBA 1414
    Mar 2015
    166
    I've always been satisfied with an M445 with that setup on my mono hulls. The X series will give you better hole shot acceleration with slightly less top end speed. The M series will give you better top end speed but will slip a bit when accelerating out of the hole. The M series will draw slightly less amps as well. You will just have to try a few different props to see which suits your purpose best.
    Nov 2008
    Ql
    3,169
    A Prather s225 is one of my favorite props on that sort of setup. Maybe even an s230 if things are running cool enough with the s225.
    https://www.offshoreelectrics.com/pr...i-prather-S225
