Results 1 to 12 of 12
Thread: Castle XLX ESC question
    Dec 2010
    NY
    2,589
    Default Castle XLX ESC question
    Hi don't laugh but are the silver things the parts that heat up also on the last pic what do they call it thanks Chris
    Apr 2017
    QL
    1,038
    are you referring to the Capacitors Chris ? the black things with silver ends.
    ON
    2,303
    Last picture is the radio board.
    Larry
    Jun 2007
    1,499
    Chris, the buss bars are the things that get hot.
    Sep 2007
    NC
    2,348
    Ray has it correct. Bus bars are what conduct heat away from the nearby FET's.
    Be careful about what you attach to the bus bars to cool the ESC as they are "hot" electrically speaking. So don't put a single aluminum plate joining both sides together as it will dead short the positive and negative.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    Dec 2010
    NY
    2,589
    No,,, the caps I know,,,,, the 3 silver bar fets I think
    Dec 2010
    NY
    2,589
    Got you Tryler, I see, castle has 1 bus insulated as they bridge it with the aluminium case thank you !
    Aug 2016
    Md
    35
    Chris,
    This thread is right on time. I am at the point that I am getting ready to put the aluminum heat sink back together after I coat the ESC boards with DP270 epoxy coating. I will keep the coating away from the bus bars and give them a coat of Artic Alumina epoxy to aid in conducting heat away but insolating the bus bar electrically. I am also keeping the insulating material that the manufacturer put on the one side of the bus bar.
    Thanks for the info
    Bruce
    Dec 2010
    NY
    2,589
    Quote Originally Posted by rat350r View Post
    Chris,
    Thanks for the info
    Bruce
    Thanks Bruce why couldn't you just get away with the Artic Alumina epoxy ?
    Aug 2016
    Md
    35
    Chris,
    I probably could but I have a receiver to also coat and the Artic Alumina is very expensive and I use it sparingly.
    Sep 2007
    NC
    2,348
    Chris aluminum with anodization is insulative. If it was a non-anodized aluminum case it would short the positive and negative
    Tyler Garrard
    Dec 2010
    NY
    2,589
    Ok I have to read up on it thanks T
