Results 1 to 6 of 6
Thread: Hobbywing ubec
    Jul 2012
    sa
    95
    Default Hobbywing ubec
    Hello once again all! Question in regards to hobbywing ubec. It is a 5v/6v 3amp max 5amp.
    I am running 6s 1600kv 200amp swordfish esc with 3.5amp sbec built into esc. Thinking of running external above mentioned ubec.
    I have never had any issues with the esc. Would you guys recommend the ubec? I Have heard stories of ubecs failing and frying receivers and servos. I have very little room left in the cat for a separate battery supply to the receiver nor do I really want to worry about another battery.
    Thoughts, positives and negatives about ubec and/or inbuilt sbec?
    As stated before no issues to date with the internal sbec.
    Feb 2018
    PA
    330
    I run both the 120 and 200....and also have had no issues with the built in sbec....... A high draw digital servo might be an issue though....
    Jul 2012
    sa
    95
    I’m running an xq power analog servo 15kg of torque.
    So an external Bec would be required more so if running a high amp draw digital servo?
    May 2018
    344
    Apr 2017
    QL
    1,038
    set up Fail Safe into your radio so if power is lost , the boat will stop.
    Mar 2014
    IA
    165
    I have several and no problems as long as you take red wire out and tape it to b and w ( signal wire ). Don't cut red wire!!!!!!!!!!!!!!
