Results 1 to 2 of 2
Thread: End point adjustments?
    Jul 2012
    sa
    95
    Default End point adjustments?
    Hi all, just gotta say I can not get enough of this forum lately. I have surely learnt a great deal and how to do things the correct way with all your help and the great threads and posts!
    So here is my next question that I am sure I will gain good information and more experience from.
    Does adjusting throttle end point on the transmitter from 100 percent to 120 percent increase rpm/power/speed or is it all relative to volts of batteries times kv of the motor? I have mine set on 100 percent.
    I realise adjusting steering end point changes the servo throw but would throttle end point make a difference?
    4,119
    Normally no, but on the older swordfish ESC's, if you calibrated your ESC to the transmitter throttle at 100%, you could still gain more RPM by then advancing the throttle range above 100. Made no sense to me and was one of the reasons I stopped using them.
