Results 1 to 7 of 7
Thread: End point adjustments?
Hybrid View
    Jul 2012
    sa
    95
    Default End point adjustments?
    Hi all, just gotta say I can not get enough of this forum lately. I have surely learnt a great deal and how to do things the correct way with all your help and the great threads and posts!
    So here is my next question that I am sure I will gain good information and more experience from.
    Does adjusting throttle end point on the transmitter from 100 percent to 120 percent increase rpm/power/speed or is it all relative to volts of batteries times kv of the motor? I have mine set on 100 percent.
    I realise adjusting steering end point changes the servo throw but would throttle end point make a difference?
    May 2018
    TX
    344
    Not one bit. It is the range an ESC uses when calibrating. I have read where some ESCs require or benefit from EPA beyond 100% but it makes no sense that it should be so. Once calibrated 100% is 100%.
    Try to keep your rudder EPA close to 100%. If you have too much throw reduce it geometrically in the linkage. I usually use the servo horn hole closest to the inside and have plenty of throw. Giving away EPA on rudder is giving away servo torque and resolution.
    ON
    2,913
    It has been proven on this forum in the past that some ESC's like a setting above 100%.
    I set my CC - ESC's to 120 % for best performance.
    Larry
    Jul 2016
    4,119
    Old swordfish 240 ESC's needed more than 100% after calibration. I hated it and that's why I stopped using them.
    Jul 2012
    sa
    95
    I have the 200amp swordfish lv esc.... do you think it may require more than 100% like the 240 esc? I’m not having any issues just curious. Not much information out there for my particular esc.
    Mar 2011
    BC
    7,630
    Quote Originally Posted by robbo1 View Post
    just try turning travel to 105-110%. You can’t hurt anything and one never knows, it may give that extra
    Jul 2016
    4,119
    Exactly. If it goes faster, it worked.
