Results 1 to 12 of 12
Thread: Help Me Choose a motor and prop
    Jun 2019
    ca
    6
    Default Help Me Choose a motor and prop
    Hello, i have a Proboat BlackJack 24.(catamaran Im ready to do some upgrades. not sure on what motor size and prop would be best. I want to get into the 40MPH club. (or higher)
    I bought a OSE Raider 150amp ESC and a 4S 75C 6500mAh
    Im looking at getting a leopard 3660 series or an X2 leopard 3660 but not sure what Kv to get?
    Leopard 3660
    2050Kv 2.5Y
    2550Kv 2Y
    Leopard X2 3660
    2380kv 4D
    3180kv 3D
    not stuck on getting a leopard motor, if you can help in selecting the right KV and prop size. im still new in the hobby. thanks for all your help.
    Mar 2017
    VI
    371
    I would go for the 2050kv 3660 and an octura x440.
    Apr 2017
    QL
    1,038
    can you buy T.P. Motors where you are ? better than the Leopards.
    Jun 2019
    ca
    6
    Quote Originally Posted by rol243 View Post
    yes, I can buy TP motors. well, what ever is on offshore electrics. Im located in California
    Apr 2017
    QL
    1,038
    The T.P. motors are a better motor than the Leopards.
    2,728
    That is a lot of weight for a 24" boat, I'd have gone for a 2860 motor of around 3400KV, on 3s 5000mAh, with a 1.4 pitch 36mm prop, and 120A ESC. it would still get you over 40mph, along with 5 minute runtimes, and likely much better handling.
    Jun 2019
    ca
    6
    mmm... im currently running a 3650 2750kv with a grimracer 40x53 prop on 3s. am i doing something wrong?
    Jun 2019
    ca
    6
    Mar 2017
    VI
    371
    In my experience, the leopards are faster than the tp.
    I cannot understand it, the tp have stronger magnets, looks to be a far better built motor than the leopard.
    And the leopard runs cooler, and holds the rpm better underload than the tp.
    The only issue I see with the leopard is they will kill bearing fast at real high rpm. Over 35000 plus rpm.
    Jun 2019
    ca
    6
    so, what KV and prop would you choose?
    I want to go 40 mph-ish
    im going to run 4S
    Mar 2017
    VI
    371
    2050kv and a octura x438 or x440.
    The weight does help to keep the boat on the water at higher speeds.
    Balancing the boat right is also very important. I would suggest a 43 percent cg.
    That is measure 10.25 inches from the rear and let that be the balance point.
    You should have neutral trim to start.
    Jun 2019
    ca
    6
    Thank you speed3! 2050kv it is. i'll get both props and play around with them. Ive never thought of balancing the boat. Im doing some reading on how to do that. Thank you for your help.
