Results 1 to 4 of 4
Thread: Battery check low voltage error
Hybrid View
    Feb 2014
    ny
    75
    Default Battery check low voltage error
    I am using a Venom dual charger. I am charging 4S LiPO batteries and it keeps showing an error that says battery check low voltage and will not charge. Battery voltage is 3.8 on two of the cells and 3.9 on the other two. I am using a y harness to charge the 2 s batteries together along with a jst Y adapter.
    Jul 2016
    4,125
    What if you try charging each pack by itself, without any Y harnesses, on a 4S charge mode?
    Oct 2019
    NY
    4
    change setting to nimh charge to it hits 4V. then switch charger back to lipo
    ON
    2,917
    Jerry
    Charge each 2S pack buy itself. then join together as 4S and balance charge.
    Larry
